La WarthObé
Nicofumi
Libellule
Libellule
Re: La WarthObé
Message non lu par Nicofumi »
obelix de savoie a écrit :
Nicofumi a écrit :Merci mano et désolé obé pour le pourrissage !!
Pas de souci :fete: :fete: et je viens de me rendre compte que j'ai zappé de te découper la frame :tete: :tete: ,je te fait sa ce week-end ;)
Pas de soucis!!! Prends ton temps ;)
Using Tapatalk
Buse
Buse
Re: La WarthObé
Bon ben c'est toujours pareil :tete: :tete: :tete:
je met les paramètres si vous voyez quelque chose qui cloche
Code : Tout sélectionner
  Entering CLI Mode, type 'exit' to return, or 'help'
# dump
Current Config: Copy everything below here...
aux 0 32
aux 1 2
aux 2 4
aux 3 0
aux 4 0
aux 5 0
aux 6 0
aux 7 0
aux 8 0
aux 9 0
aux 10 0
aux 11 0
aux 12 0
aux 13 0
aux 14 0
aux 15 0
aux 16 0
aux 17 0
aux 18 0
aux 19 0
aux 20 0
mixer QUADX
feature -PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -SERIALRX
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -LED_RING
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -POWERMETER
feature -VARIO
feature -3D
feature VBAT
map AETR1234
set looptime = 3000
set emf_avoidance = 0
set midrc = 1500
set minthrottle = 1039
set maxthrottle = 1900
set mincommand = 1000
set mincheck = 1100
set maxcheck = 1900
set deadband3d_low = 1406
set deadband3d_high = 1514
set neutral3d = 1460
set deadband3d_throttle = 50
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set retarded_arm = 0
set flaps_speed = 0
set fixedwing_althold_dir = 1
set reboot_character = 82
set serial_baudrate = 115200
set softserial_baudrate = 9600
set softserial_1_inverted = 0
set softserial_2_inverted = 0
set gps_type = 0
set gps_baudrate = 0
set serialrx_type = 0
set telemetry_provider = 0
set telemetry_port = 0
set telemetry_switch = 0
set vbatscale = 110
set currentscale = 400
set currentoffset = 0
set multiwiicurrentoutput = 0
set vbatmaxcellvoltage = 43
set vbatmincellvoltage = 33
set power_adc_channel = 0
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set yaw_control_direction = 1
set acc_hardware = 0
set moron_threshold = 32
set gyro_lpf = 98
set gyro_cmpf_factor = 600
set gyro_cmpfm_factor = 250
set pid_controller = 0
set deadband = 0
set yawdeadband = 0
set alt_hold_throttle_neutral = 40
set alt_hold_fast_change = 1
set rc_rate = 90
set rc_expo = 65
set thr_mid = 36
set thr_expo = 0
set roll_pitch_rate = 0
set yaw_rate = 0
set tpa_rate = 0
set tpa_breakpoint = 1500
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1200
set failsafe_detect_threshold = 985
set rssi_aux_channel = 0
set yaw_direction = 1
set tri_unarmed_servo = 1
set gimbal_flags = 1
set acc_lpf_factor = 4
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = 1
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set gps_pos_p = 11
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 20
set gps_posr_i = 8
set gps_posr_d = 45
set gps_nav_p = 14
set gps_nav_i = 20
set gps_nav_d = 80
set gps_wp_radius = 200
set nav_controls_heading = 1
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set p_pitch = 40
set i_pitch = 23
set d_pitch = 15
set p_roll = 40
set i_roll = 23
set d_roll = 15
set p_yaw = 85
set i_yaw = 45
set d_yaw = 0
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 70
set i_vel = 45
set d_vel = 1
Foxxy
Re: La WarthObé
Message non lu par Foxxy »
On va demander à Anta de nous faire un dump de sa configuration, bien qu'il soit paramétré en 3D on pourra quand même se faire une idée.
Anta, si tu lis; et si tu peux nous donner un coup de main Il faudrait connecter ta Naze sur Baseflight tu vas dans l'onglet CLI et tu tapes juste la commande dump. Ne t'inquiètes pas, ça ne change aucune valeur de réglages, ça permet juste de lire les valeurs.
A l'écran tu vas avoir un tas de valeurs qui s'affichent tu les sélectionnes toutes, tu fais un copier, et tu les colles entre deux balises Code s.t.p.
Si il y a d'autres potos qui ont une Naze32 qui est bien réglée, merci de donner un coup de main à OB en faisant la même manip.
Pour OB, là ce sont les valeurs de ma carte, mais elle n'a pas encore pris l'air donc ce sont les valeurs "sortie d'usine"
# dump
aux 0 32
aux 1 2
aux 2 4
aux 3 0
aux 4 0
aux 5 0
aux 6 0
aux 7 0
aux 8 0
aux 9 0
aux 10 0
aux 11 0
aux 12 0
aux 13 0
aux 14 0
aux 15 0
aux 16 0
aux 17 0
aux 18 0
aux 19 0
aux 20 0
mixer QUADX
feature -PPM
feature -VBAT
feature -SERIALRX
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -LED_RING
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -POWERMETER
feature -VARIO
feature -3D
feature VBAT
map AETR1234
set looptime = 3000
set midrc = 1500
set mincheck = 1100
set maxcheck = 1900
set flaps_speed = 0
set gps_type = 0
set vbatscale = 110
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set gyro_lpf = 98
set deadband = 0
set yawdeadband = 0
set rc_rate = 90
set rc_expo = 65
set thr_mid = 36
set thr_expo = 0
set yaw_rate = 0
set tpa_rate = 0
set gps_pos_p = 11
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 20
set gps_posr_i = 8
set gps_posr_d = 45
set gps_nav_p = 14
set gps_nav_i = 20
set gps_nav_d = 80
set p_pitch = 40
set i_pitch = 23
set d_pitch = 15
set p_roll = 40
set i_roll = 23
set d_roll = 15
set p_yaw = 85
set i_yaw = 45
set d_yaw = 0
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 70
set i_vel = 45
set d_vel = 1
willoo
Modérateur
Modérateur
Re: La WarthObé
Message non lu par willoo »
Anta est partie faire une séssion de vol plutôt loin de chez lui donc pas d'inquiétude si il ne répond pas desuite.
Black-out mini h
manolozen
Souscripteur
Souscripteur
Re: La WarthObé
La seule fois Obé ou mon multi me tapait des flips inopinés, c est quand j'ai monté la rosewhite en étant persuadé que le carbone n'était pas conducteur et pour tester vite fait j'avais pas mis de gaine thermo sur les esc, bein j'ai remballé vite fait aussi :mrgreen:
Je pouvais décoller et dès que je touchais au P/R ça partait en crêpe, p t être une piste, t'as pas un chti court circuit qq part?
Buse
Buse
Re: La WarthObé
Si je vais molo sur les manches sa va nickel je peut voler ,elle tiens le statio aussi . c'est des que je donne des coup de manches rapides en rool et pitch que sa fait la crêpe comme si les accelero n’arrivais pas a suivre
manolozen
Souscripteur
Souscripteur
Re: La WarthObé
obelix de savoie a écrit :Si je vais molo sur les manches sa va nickel je peut voler ,elle tiens le statio aussi . c'est des que je donne des coup de manches rapides en rool et pitch que sa fait la crêpe comme si les accelero n’arrivais pas a suivre
T'as essayé en gyros seuls ?
anta377
Re: La WarthObé
Message non lu par anta377 »
Foxxy a écrit :On va demander à Anta de nous faire un dump de sa configuration, bien qu'il soit paramétré en 3D on pourra quand même se faire une idée.
Je te fais ça demain chef ;) ;) car là je suis vanné, session de vol oblige avec le pro et sa nouvelle zenmuse h3 3D :super:
Foxxy
Re: La WarthObé
Merki .... A un moment, il faut aussi penser à se reposer :mrgreen: Parce que (hélas) les journées n'ont que 24H00 :cris: :cris:
Re: La WarthObé
voila les valeurs de base de ma flip32 acro ,dans laquelle j'ai mis la 3D,mais elle n'a pas encore volé.
# dump
aux 0 8
aux 1 0
aux 2 6
aux 3 0
aux 4 0
aux 5 0
aux 6 0
aux 7 0
aux 8 0
aux 9 0
aux 10 0
aux 11 0
aux 12 0
aux 13 0
aux 14 0
aux 15 0
aux 16 0
aux 17 0
aux 18 0
aux 19 0
aux 20 0
mixer QUADX
feature -PPM
feature -VBAT
feature -SERIALRX
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -LED_RING
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -POWERMETER
feature -VARIO
feature -3D
feature VBAT
feature 3D
map AETR1234
set looptime = 3500
set midrc = 1500
set minthrottle = 1150
set maxthrottle = 1850
set mincheck = 1100
set maxcheck = 1900
set flaps_speed = 0
set gps_type = 0
set vbatscale = 110
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set gyro_lpf = 42
set deadband = 0
set yawdeadband = 0
set rc_rate = 90
set rc_expo = 65
set thr_mid = 50
set thr_expo = 0
set yaw_rate = 0
set tpa_rate = 0
set gps_pos_p = 11
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 20
set gps_posr_i = 8
set gps_posr_d = 45
set gps_nav_p = 14
set gps_nav_i = 20
set gps_nav_d = 80
set p_pitch = 40
set i_pitch = 30
set d_pitch = 23
set p_roll = 40
set i_roll = 30
set d_roll = 23
set p_yaw = 85
set i_yaw = 45
set d_yaw = 0
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
